Error show toner level bizhub 454e
  • dacam20590
    • May 2019
    • 30
    I have a problem with the toner level display of the bizhub 454e. The machine says out of toner and I have replaced the new toner cartridge and it shows 25% toner level value. Why is it not showing 100%. I changed 2 other toner cartridges and new chip and it still shows 25%. I take out the toner cartridge and the machine still shows 25%. I sometimes encounter 3 4 such machines. The machine still works normally
    • 14335
    Re: Error show toner level bizhub 454e
    [ATTACH=CONFIG]50860[/ATTACH]
    It's because the toner level is not stored on the chip. All the chip does is tells the machine it is the correct toner. When the toner is replaced early the machine doesn't know it is a new full toner, it retains the previous level. Nothing bad is going to happen.
    • dacam20590
      • May 2019
      • 30
      so how to fix this. Is it related to dips switch?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4512
        Those toner gauges on the display are very touchy and not that accurate. If you remove the btl with machine on it can cause gauge to change. Mostly showing full when btl could be empty.
        I tell my customers to disregard the toner gauge altogether and wait for message to replace toner. Have most of my customers trained to call for another toner when putting last one in so always have one on hand. Years ago I printed up labels to put on toner btls "Please call to re-order when installing this last toner". Was tired of customers calling in panic saying the machine stopped working because of no toner. They would always say "but the toner gauge showed 1/2 full" so was waiting to order!
        • rrrohan
          • Sep 2011
          • 1977
          AFAIK only 8 series on have dipswitch to report full
          You could remove toner and deplete hopper with with vac or 100% coverage prints on that colour then only put toner in when it asks for it
          Sent from my Pixel 4 XL using Tapatalk
          • dacam20590
            • May 2019
            • 30
            So I had to suck out all the toner from the hopper. and take out the toner cartridge then copy the 100% coverage until the toner runs out, then put the new cartridge in?
            • femaster
              • May 2011
              • 1458
              That should do it. The goal here is to make the copier tell you that it needs to be replaced. Only then will it reset the gauge.
              • rrrohan
                • Sep 2011
                • 1977
                yeah. i normally dont bother resolving this for customers since they have already wasted toner by replacing it early im not gonna waste even more to get the gauge to read correctly
                thankfully on the 8 and newer they put a engine dipswitch to set gauge to 100%
                • copier tech
                  • 8096
                  No need to vacuum out the hoppers.
                  Take all the toners out, put them back in the box turn off the low toner waring in CE mode then tell your client to replace the toner only when you machine prompts them to.
                  This way the counter will show 0 % until they fit the toner back it will show 100%
                  • dacam20590
                    • May 2019
                    • 30
                    i thinks fix dipswitch bit 151 ?
                    • tsbservice
                      Field tech
                      • 7904
                      No such DipSW...soft switch maybe
                      • rrrohan
                        • Sep 2011
                        • 1977
                        31 32 33 34 Y M C K
                        But afaik 4 series don't have this feature unless that's changed since I looked 2 years ago
