bizhub PRO 1100
  • Pandas
    • Sep 2011
    • 14
    bizhub PRO 1100
    Hello. I have the following problem. I turn on the engine and on the screen I have the message "Please wait.starting system". The engine does not enter service mode. Has anyone encountered this problem??
  • Synthohol
    Certified Konica Expert
    • 5733
    i hope its this simple for you..
    This gallery has 1 photos.
    • Pandas
      • Sep 2011
      • 14
      the machine does not reach the point of warming up. it stays at the white screen.εικόνα_Viber_2025-03-24_14-12-25-020.jpg
      • wjurls
        • Feb 2017
        • 490
        Most likely the hard drive. Try to disconnect the drive and reboot the machine.
        • Pandas
          • Sep 2011
          • 14
          I tried it but it does the same thing.
          • wjurls
            • Feb 2017
            • 490
            Try opening the system box and reseat all the connectors to and from, as well as between the SSD, OACB and Image Control boards. If this persists, you may need an Overall Control Board or SSD.
            • Pandas
              • Sep 2011
              • 14
              I've tried with the connectors and nothing happens. It's probably the SSD. Can I copy it from another machine?
              • wjurls
                • Feb 2017
                • 490
                Can you get into service mode and try to reformat it? Service manual says contact KM for replacement.
                We tried moving one from one machine to another in the past and it didn't work.
                • Pandas
                  • Sep 2011
                  • 14
                  • ps-tech
                    • Oct 2023
                    • 5
                    I had this problem on Accurio C3070. We replace SSD with help from KM service manager. It was under waranty so they changed it and instal firmware. I remeber that was a specific instalation order of firmware.
                    • Pandas
                      • Sep 2011
                      • 14
                      Thank you very much for the information.
                      • Pandas
                        • Sep 2011
                        • 14
                        I finally changed the ssd and the engine started normally. Thank you all for your help.
