Poor print quality on Konica Minolta C454e
  • U12runzn
    • Jan 2022
    • 5
    [Misc] Poor print quality on Konica Minolta C454e
    Hi I'm having issues when I print , the page background has black shades that get worse as the machine prints . As if the prints are dirty .
    Steps taken in attempt to resolve the problem -
    Changed entire drum unit Corona wire included
    Changed developer
    Change transfer belt
    Everything was changed with original parts
    Cleaned printhead laser glass
    Technician went into service menu and calibrated a few times
    It seems as if the first printed less dirty and as the machine prints more copies the black shadow increases. It prints all colours but the black shadows print over .
    What else could possibly be wrong with this machine
    The technician thinks the HV needs replacing .
    I'm not sure if this is related to the issue but the last toner inserted into the machine was depleting very quickly while printing however it was printing perfect
  • Synthohol
    Certified Konica Expert
    • 5731
    Re: Poor print quality on Konica Minolta C454e
    lemme ask you, were entire brand new OEM units replaced or simply rebuilt?
    i ask because you said developer not developer unit which suggests only the powder.
    you also mentioned including the corona wire, if an OEM unit were replaced that wouldnt be a detail i would need to mention.
    if this is the case try new units from KM, unless you have a front side board you can swap from another machine?
    • Max
      • Oct 2011
      • 544
      Go to service mode and print out C Y M K test sheets. Line them up and if white lines line up then it will be the belt. Waste belt relay pipe not blocked? If not, developer gap blade contaminated with clumps of toner preventing uniform brush. Oem/compatible toner? Take out laser unit and clean glass by hand as magic wand doesn't always work. Compatible drums don't always work. Possibly transfer roller but in my experience unlikely nor HV board.
      • U12runzn
        • Jan 2022
        • 5
        Thanks your post was very helpful. Problem sorted
        • U12runzn
          • Jan 2022
          • 5
          Issue with the laser unit . Thanks for your feedback
