Konica Minolta c654e - fiery E100 undefinedresource error
  • Outlander Kyle
    • Nov 2021
    • 15
    I installed the ic-414 fiery for this machine - figured out how to set up all the software and even successfully print from the E100 software.
    However, I much prefer the Konica Minolta bizhub c654e PS software because certain options like offset printing from the finisher are not a part of the e100 driver.
    When I set up the print driver with that software - my prints come out saying
    ERROR:undefinedresource
    OFFENDING COMMAND: findresource
    STACK:
    /ProcSet
    /KMOptions
    -dictionary-
    anyone faced this and found a solution? other driver setups work normally, just feel limited. thanks.
  • Synthohol
    Certified Konica Expert
    • 5734
    the fiery driver will have all the options the emperon driver does afaik, is it setup correctly for LPR with Print as the queue name? enabled 2 way communication?
    you shouldn't use the wrong driver. you can use the IP the fiery designated for the copier (usually 1 # up) and use the emperon ps driver and the fiery will passthrough the job to it but i dont recollect any finishing options that were not in both drivers.
    fwiw on the fiery webpage there is a tab for downloads. i usually grab that and extract the drivers and manually install it LPR.
