Konica minolta bizhub C364e touch screen not working
  • ronsh
    • Jan 2022
    • 5
    Hi we have a bizhub c364e, the printing is working fine but we just noticed the touch display not working at all. The physical buttons around the touch screen is working, but not any of the buttons on the touch screen. So we can not access any extended menu etc. cannot scan.
    What could be the problem? Many thanks for any advice.
  • tmmdmmm
    • Apr 2021
    • 173
    Re: Konica minolta bizhub C364e touch screen not working
    Internal ribbon cables or board. You could try a reboot, trouble reset, or SEC if you know how to do them just to see if its an odd glitch. Generally we just replace the op panel if it has any issues. Isnt terribly hard to do, but if you're an end user I'd call a tech
    • Synthohol
      Certified Konica Expert
      • 5727
      try to plug in a USB mouse to the panel USB.
      it may have been a production machine i did it to but ya never know.
      seen it work.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        seen it work.
        Nope, doesn't work. Because I was curious and haven't ever tried this, I just did on our C284e and it lights up the mouse but nothing else happens. Tried it on our C360 and I get an icon that's for USB connected but it has a red X on it.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • rrrohan
          • Sep 2011
          • 1977
          so screen works just not the touch aspect?
          • femaster
            • May 2011
            • 1458
            Give this thread a read through, especially post #6 in it. Run the screen calibration using method "b" and see if that revives it at all.
            https://www.copytechnet.com/forums/konica-minolta/150321-km-bizhub-c364e-touch-panel-unresponsive-post1542054.html?150321=#post1542054
            • femaster
              • May 2011
              • 1458
              I made an error when I typed that out apparently. Try the screen calibration using method "a". You obviously can't use method "b" if the touch screen doesn't work at all. Sorry, momentary laps of sanity...
              • ronsh
                • Jan 2022
                • 5
                Thanks for all the replies! Yes screen works just not the touch aspect. It was working at least a month ago. (scan was not used often so don't know when the touch started to fail.) Will try with suggestions and report back.
                Thank you.
