Today had 2 C3320i with same problem, over consume Magenta toner both with 10k counter +-.... is the G00-B5 still a good fix for this?
Increased (M)Toner Consumption C3320i
Re: Increased (M)Toner Consumption C3320i
I think G00-M2 is the latest FW - you'll find some more infos obout this problem in other threads. I think it was about the C3350i/c4050i but they share the same engine. Short version: There's some sort of "high speed dev mix mode" added in newer firmware you can perform to remove clogged dev/toner from the TD sensor. I think you have to check some voltages before/after the procedure and if they don't improve the IU might be bad. -
one of the big problems is the gradation is not being done at set up. so the voltages are screwed up. they all read 0. after you get the ratio's where they need to be do the gradation. i have not had a problem since i do this step. in some cases you may need to start with new image unit. i have seen yellow do this as well.Comment
It's been a while since the high speed agitation firmware came out and dare I ask if anyone has noticed any improvements with IU reliability ?
Just asking as we seem to be going through a few imaging units again.Comment
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Latest firmware is G00-N4. see attached for toner depletion problemImage Units Depleting .pdfBulletin Number 12202.pdfAttached FilesComment
You forgot to add - all the paper trays have to be openTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
We have loaded the firmware since its launch and done the high speed agitation, however the problem seems to come back especially if the machine is sat idle for a while.
Previously we had similar experiences with the C1070 print production machines when they were switched off over Xmas.
I am aware of the developer unit modification and I have been informed that these wont appear in the UK until Feb at the earliest.Comment
Our impression of the machine is it isn't fit for purposeComment
