C3300i toner
  • jwai
    • May 2018
    • 499
    C3300i toner
    Dear all,
    I wanna ask, how many pages of initial toner cartridge( mainly text documents )already installed in new printer?
    Best regards,
  • Gift
    • Mar 2011
    • 2444
    Re: C3300i toner
    AFAIK there are no "starter" cartridges installed
    • jwai
      • May 2018
      • 499
      Re: C3300i toner
      Our Asia pacific region there have 4 toner cartridge been installed into printer.
      One customer called M toner nearly empty, however the color printing is quite low.
      • femaster
        • May 2011
        • 1458
        Re: C3300i toner
        There is an issue with that style of machine where the developer mix is getting compacted on the bottom of the image units. There has been firmware updates to address the issue, but if the problem is already happening the image unit may need a little help also. That is most likely what is happening with that machine.
        We had a C3350i that was going through magenta toner like crazy. I found that the TCR value in magenta never changed, and was stuck at around 4.65% all the time. The machine was constantly adding magenta toner. I ended up removing the magenta image unit and tapping along the whole bottom of the unit with the handle of my screwdriver, especially near the sensor, to free up the compacted developer. After reinstalling the image unit, the TCR value was up over 10%. I ran a number of half-tones at 255 to bring the level down near normal and it has been working perfectly ever since.
        Start with making sure you have the latest firmware and function version. After that I'd pull out each image unit and tap the bottom of them. You will hopefully be good to go afterwards.
        • jwai
          • May 2018
          • 499
          Re: C3300i toner
          I visited the customer, color printed 28XX black 12XX, firmware G00-J9.
          The machine showed replace toner M, so i checked TCR first M had 6.0%, others 6.XX.
          It ran long long time after new toner is replaced, i removed the new toner out, checked shutters of both previous toner cartridge and IU and rotation of toner supply motor and toner cartridge.
          I removed IU(M) and found a thin layer toner on drum surface, cleaned contacts and checked sleeve roller.
          Poured a little lit toner to IU(M), installed back original toner cartridge and ran few minutes the predrive stopped, checked TCR (M) is 5.98
          Got TCR toner supply of service mode, TCR (M) changed to 6.34
          • jwai
            • May 2018
            • 499
            Re: C3300i toner
            I checked both C3300i and C3320i they don't have toner reset mode if toner chip malfunction, right?
            • elmaligno
              Expert technician KM
              • Oct 2009
              • 296
              Re: C3300i toner
              Field technician since 1994
              • tech51
                • 846
                Re: C3300i toner
                Yes they do. Engine firmware switch 6.
                Doesn’t reset the gauge but allows the machine to run.
                Set the switch, exit service mode and open/close the front door.
                It some times takes a few goes opening and closing the door for it to come ready.
                Just depends how undertoned the relevant iu is.
                • tech51
                  • 846
                  Re: C3300i toner
