C308 SSD Board Replacement / Availability
  • femaster
    • May 2011
    • 1466
    Making a long story short here. We have a C308 that does not boot past 2 bars. We've done extensive troubleshooting on it, and determined that it is the SSD board that has failed. MFPB works perfectly in another test machine with that machines NVRAM and SSD board attached to it.
    Attempted to order a new SSD board from Konica and, according to their online ordering site, the part has been discontinued and can no longer be ordered. I don't know the part number off the top of my head, and can't pull it up at the moment, but it was what was listed in the latest parts manual. There is actually 2 listed in the parts manual, both are discontinued. I can't see how that is possible as there is a parts availability guarantee, and this model is not end of life. I can find no alternate part numbers, no bulletins mentioning anything at all about this.
    Anyway, has anybody ever successfully swapped out a used SSD from another machine on the 8-series? That is what we are currently looking into as one of our options. If anyone has attempted this, successfully or not, and can provide any insight into issues we may face with doing this, it would be greatly appreciated.
  • Reed
    • Feb 2011
    • 250
    Re: C308 SSD Board Replacement / Availability
    I have done it on the 4e series. I used on from a B/W model on a Color machine. It did change the meter and I noticed the new color meter was "0" . The ssd board will also have other information from the previous machine. Which needs to be changed. Good luck let us know how it goes if you do it!
    Also thats weird they discontinued it as I have recently purchased an ssd for the 4e series.
    • tsbservice
      Field tech
      • 7924
      I believe they called it emmc. Never had one fail.
      Hope Albonline isn't on vacation.
      • femaster
        • May 2011
        • 1466
        I also thought is was strange that it came up as discontinued. For the heck of it, I looked up one from a C287, since they are essentially the same physically, and that was also listed as discontinued. I didn't think to try a 4e, as they are a different style board.
        We are still weighing our options, but that is kind of what I was afraid of was bringing the meters and what not from a different machine into this one. I know that the 8-deries uses 2 EPROM chips on the main board, which also stores backups of data like meters and what not. I'm afraid that if we attempt to use a different SSD, things may get ugly because the data between the 2 wouldn't match. If there was a way to force it to pull the data from the EPROMS and overwrite what's on the SSD, we might be successful.
        • femaster
          • May 2011
          • 1466
          You are correct. The parts book and some locations in the service manual do refer to it as an eMMC board. That term actually refers to a type of interface, but that isn't accurate either. These actually use an mSATA interface not eMMC, so Konica really isn't using proper terminology for these. But, that's a story for another day...
          • Oystercopy
            • Oct 2009
            • 618
            I have not had the need to order an SSD (EMMC) from KM for the 8 series, but the last time I tried to order one for a 4 series, it was like PULLING TEETH... the hotline people were absolutely useless and would not order one for me because I was "not the original seller of the machine". I almost never am.
            In any event, NO it should definitely not be discontinued, so I would get someone at KM to help out, other than your normal parts person.
            OC
            • copyman
              Owner / Technician
              • Sep 2005
              • 4542
              If in fact the 8 series SSD is no longer available this just adds to the demise of Konica Minolta. What they put their dealers & customers through this last year with toner & machine shortage is shameful to say the least! They are getting worse not better. What sucks is I've been upgrading all my customers with the 4 series to the 8 series and if they make parts hard to get or discontinued I'm screwed! I would prefer to stay with the 4 series but there have been a lot of issues with scanning security, etc so no choice but to upgrade. I believe Kon/Min machines are getting worse not better and designed not to last much past a lease period of 3-5 years if your are lucky. If I wasn't getting close to retirement I would switch to Canon!
              • Woxner
                • Jul 2011
                • 829
                These are avalible. Not discontinued
                A7AHH02D02
                They useally require tech support approval and managers order them
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4542
                  A7AHH02D02
                  Hey Wox,
                  Good to know. Makes me feel a little better.
                  By the way why is approval needed to order SSD? Only thing I can think of is because a new SSD can reset the meters and they don't want someone selling a used machine as new?
                  • tmmdmmm
                    • Apr 2021
                    • 173
                    A7AHH02D02
                    Like button doesn't seem to work but this is correct. I've had the emmc(ssd) fail on a C308 causing the same issues, won't boot past 2. Manager had to order it, but I did not go through tech support for it prior. Same with a few SB issues, managers had to order.
                    • allan
                      RTFM!!
                      • 5459
                      This document helped me a bunch and touch wood I have not bricked a machine yet.
                      Case 4 states the counter data will move from the spares machine to your current machine.
                      I have done this before. The EEPROM holds the engine data so don't move that. Else replace or move all parts from spares machine.
                      Or I will just replace all the ICP'c on the units in that case.
                      Board replacement cases.pdf - Google Drive
                      Whatever
                        • 22942
                        Thank allan! I hope I never need to use this information. =^..^=
                        • femaster
                          • May 2011
                          • 1466
                          A7AHH02D02
                          It must have something to do with you being in the UK. Just for shits and giggles I tried it again with the same result, "discontinued":
                          • tmmdmmm
                            • Apr 2021
                            • 173
                            Thank you, this'll save me one day. Odd, the i series cert powerpoint had the board layout but not the various case scenarios
                            • Albonline
                              • Sep 2008
                              • 1133
                              you can move the ssd and mfp/driver board with the eeprom located behind the hv board. this will make the target machine into the donor machine. reset sn and relicense. Unit ,or you could get somebody from km to order it for you
                              A7AHH02E03 **CONTACT CSC** PWB ASSY (PWB-EMMC) 1 0 30.4 CSC APPROVAL REQD
