Bizhub C227 error C-3925
  • otphas
    • Aug 2019
    • 107
    Hi Guys ,
    Bizhub C227 start with error code C3925 , we found a misfeed paper inside in the fusing unit . All is cleaned and all small paper was taken out , but error still popping up after trouble reset .
    Regards
    Otphas
  • tsbservice
    Field tech
    • 7904
    Re: Bizhub C227 error C-3925
    Originally posted by otphas
    Hi Guys ,
    Regards
    Otphas
    Does the fuser heats at all? Can you put for the testing purposes another well known fuser?
    • otphas
      • Aug 2019
      • 107
      Other fuser work fine on this machine . And also i checked problematic fuser and was not hot .
      • Albonline
        • Sep 2008
        • 1131
        thermal fuse smoked in fuser. they call it a thermostat but getting it to reset and be reliable won't happen.
        • otphas
          • Aug 2019
          • 107
          Termo fuse is not fired !
          • Albonline
            • Sep 2008
            • 1131
            • otphas
              • Aug 2019
              • 107
              Will try tomorrow !
              • tsbservice
                Field tech
                • 7904
                Will try tomorrow !
                I guess you may try another working thermostat from old beaten fuser...
                • Albonline
                  • Sep 2008
                  • 1131
                  Will try tomorrow !
                  check the heater lamp for open also.
                  • otphas
                    • Aug 2019
                    • 107
                    Lamp is not broken , but will check it !
                    • tulintron
                      • Jul 2014
                      • 665
                      I love thermofuser.They are solid. I tap lightly and he returns to driving
