4752 lifestop
  • BR549
    • 109
    4752 lifestop
    Does anyone know how to disable life stop for the IU on the 4752? Thanks.
  • Synthohol
    Certified Konica Expert
    • 5734
    Re: 4752 lifestop
    2.6 Life Stop Setting
    2.6.1 Life stop
    (1) Use
    • To select whether or not to stop a print cycle when the maintenance kit reach its service life.
    NOTE
    ▪ The settings of software Dip switch No.227 (bit7) and switch No. 230 (bit3) have priority.
    (2) Default setting
    • Off
    (3) Setting item
    • Enable
    • Off
    if it has already reached life the message may not go away, this is normally set prior to install.
    • tsbservice
      Field tech
      • 7904
      Re: 4752 lifestop
      Synthohol kindly this is for maintenance kit parts and OP asked about IU(drum-dev combo). Which is also in manual simply can't remember function/code.
      • Synthohol
        • 5734
        Re: 4752 lifestop
        life stop is for drum and DV.
        it can be overridden by those 2 dip sw.
        also i wasnt aware of any konica maintenance kit for a office model. just for production machines.
        • tsbservice
          Field tech
          • 7904
          Imaging unit Imaging unit: DisplayConsumable Life ReminderImaging unitSW No.051 HEX 00 - HEX80Imaging unit
