convert dat files to csv?
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    i know this has been asked but im not a konica repair guy. I have a backup of a customers konica address book and more with the .dat extensions.
    how can i use pagescope data admin to convert this to csv?
    I fix copiers ...Well Sorta
  • Ziggy
    • Feb 2018
    • 676
    Re: convert dat files to csv?
    Not sure if you can but user manual attached
    • Synthohol
      Certified Konica Expert
      • 5727
      was never meant to be converted, thats why csv is the 2nd option when saving usually.
      the dat file if i remember you open in notepad and change the model and serial string to one you can produce from the newer copier.
      then it imports ok.
      • emujo2
        • Mar 2017
        • 1580
        You can create a virtual device, load your .dat file here, then export the AB in Tab Text style. This can be opened with excel and saved as .csv. E
