konica minolta c300i replace toner c and y indicators on
  • brent
    • Nov 2008
    • 1208
    like stated above.. the panel indicates they need toners and they just don't I am using genuine toner as well not refills or aftermarket
    any thoughts? thanks so much
    brent
  • Brad6784
    • Mar 2015
    • 62
    • brent
      • Nov 2008
      • 1208
      Re: konica minolta c300i replace toner c and y indicators on
      this machine was just fine until we moved it. lol I will check this out.. I just had to do a c364e hopper a couple weeks ago it took a llittle time for sure but it was the problem was the toner hopper as well.. this machine is new enough that I don' thave a spare hopper around like the c364 which I have lots of used parts for
      brent
      • femaster
        • May 2011
        • 1458
        There are known issues with the toner units on these models. If you have access to the KM knowledge base, look up KBA00074915 and KBA00052227. I'll copy the text below, but one of them has a PDF attachment that I'm not able to include at the moment.
        Related Products:bizhub C250i,bizhub 300i,bizhub 360i,bizhub 450i,bizhub 550i,bizhub 650i,bizhub 750i,bizhub C300i,bizhub C360i,bizhub C450i,bizhub C550i,bizhub C650i,bizhub C750i
        Problem
        Low TCR, broken toner drive, premature replace toner messages.
        Solution
        CAUSE: The detecting plate coming off of its hinge pin. The issue is currently being investigated by Konica Minolta Incorporated (KMI) R&D, and a permanent solution will be provided once that investigation is completed.
        SOLUTION: Please refer to the attached documented procedure.
        Related Products:bizhub C250i,bizhub C300i,bizhub C360i,MFX-C2595i,MFX-C3095i,MFX-C3695i
        Problem
        "Toner low" message will occur even if the toner bottle is new or full.
        Solution
        CAUSE: The two sided tape and sponge is out of position causing the inner shutter to not open properly
        SOLUTION: Press the upper part of the inner shutter if the shutter does not open properly cut the sponge/ two sided tape back
        Note: Open a ticket with the Contact Support Center (CSC) at 1-800-825-5664 if you have an affected toner cartridge and provide the following information.
        • Provide the Lot Numbers to identify toner cartridges affected:
        • The first four digits are the production date, the sixth digit is the color data(C/Y/M/K) Example(9403AMD9) September 4th 2003 Magenta toner
        • brent
          • Nov 2008
          • 1208
          thank you I am a dealer but horrible at reading the knowledge base. I will certainl y do that.. thank you so much
          brent
          • copier tech
            • 8093
            brent
            Use engine SW 31, 32, 33, 34 to reset the toner counts this will reset the 'gas gauge' to full.
            Next restart & perform a colour print run. Check the TCR levels stay around 6.5%
            As always keep the firmware at the latest.
            • femaster
              • May 2011
              • 1458
              brent
              I don't blame you much for that, The knowledge base has always been a pain to find anything. It has gotten better it seems, but it's still far more difficult than it should be to find things in it.
              • tsbservice
                Field tech
                • 7899
                Lol, your knowledge base is super compared to what we have.
                Especially AAS is top notch.
                • brent
                  • Nov 2008
                  • 1208
                  lol try calling in a ticket in the old days it was so painful. and somethimes they told me they never heard of the problem before lol I do believe one of the techs was malcolm years ago
                  • brent
                    • Nov 2008
                    • 1208
                    femaster.. question for you are you talking about the toner bottle shutter or the shutter in the toner hopper in the copier? the 2 toners it is calling for once I cremove the bottle and in the machine I move the shutter they are both packed full with toner.. interesting just was curious thank you so much
                    Problem
                    Solution
                    Problem
                    Solution
                    • Synthohol
                      Certified Konica Expert
                      • 5727
                      the corrugated tube that delivers toner to the dv unit also gets clogged.
                      • Ziggy
                        • Feb 2018
                        • 676
                        Problem
                        Solution
                        Problem
                        Solution
                        Attached is the pdf that is mentioned in KBA00074915
                        • occus
                          • 317
                          Had only 2 Machines in 2020 with TRC low Sub Hopper Assy problems.
                          Since half a year I had about 6 cases on C250i-C650i where the toner bottle was not recognized as new. The toner indicator remained at 0. I think it is the Chip or contact.
                          The TCR value was always ok, so I did a reset and the problem was solved. Unfortunately it was not possible for me to check if the chip increased the counter in Service Mode Counter Parts Life.
                          If someone has such a case and it is the first toner that needs to be replaced then he should please check the counter. Then you would know the problem is the chip .
                          After Initial Setup the counter stays on 1! If you replace your first toner ist should stay on 2.
                          • Kenny
                            • Jun 2009
                            • 515
                            i had a cyan toner set issue on a C360i, had to do the attached to resolve KOM191501-2.pdf
                            • femaster
                              • May 2011
                              • 1458
                              Sorry for the late reply, been a few days since I've been here. Unfortunately I've not had to deal with this situation as of yet, so I can only speculate on what they mean in the bulletin. After re-reading the bulletin, it really sounds like it could be either shutter, they were clear as mud in their description. My best educated guess would be the shutter on the toner bottle only because near the end they talk about having "an affected toner cartridge". Unfortunately that is only a guess on my part.
