Konica Minolta c450i
  • WisamM
    • Feb 2023
    • 16
    [Misc] Konica Minolta c450i
    Hi,
    After installing new Firmware, I tried to log in as Administrator but the Default CE password doesn't work (1234567812345678) and the password for the Service Mode doesn't also work (9272927292729272).
    For sure I tried other passwords but the same result came again.
    Note: No one has changed the Default passwords.
    What can I do???
    Thanks in advance
  • femaster
    • May 2011
    • 1457
    Re: Konica Minolta c450i
    Try getting into CE through the trouble reset screen and see if the default password works there.
    • Synthohol
      Certified Konica Expert
      • 5727
      boot to a firmware stick but select "machine type select" and verify they arent both set to FF.
      if there are other numbers and letters you can leave it alone.
      its worth checking.
      • Ziggy
        • Feb 2018
        • 676
        Originally posted by WisamM
        Hi,
        What can I do???
        Thanks in advance
        How far of a jump in firmware did you do? Try rolling machine back to what was on it, then stepping it up. I don't skip over function levels, if coming from function level 1 I go to the lowest function level 2 firmware then set it to function level 2 . then I step up to next function level until I get it up to the latest. Another thing to note , I know it sounds weird but when coming from very early firmware when upgrading it would do strange stuff if movie firmware didn't match was it said it should have in the read me. So if you are coming from a very early version firmware delete movie data (aka Image Data ) until you get machine up to latest level then install latest movie (image) data.
        • rrrohan
          • Sep 2011
          • 1977
          the admin mode wont work if you set the function version higher than the firmware supports
          • techsxge
            • Jan 2022
            • 660
            Does this also apply for webmode?
            • Synthohol
              • 5727
              admin access security is the same via web or panel.
              did you check the machine&type?
              • REGSIS
                • May 2016
                • 434
                its worth checking.
                I can confirm that service mode couldn't be entered if wrong machine type is set.
                But if this is the case it would show a service call error after startup.
                I would check CPU board with diagnostic tool.
