Universal Driver v4 with Account Track Popup window
  • gavrielx
    • Oct 2015
    • 57
    Hi,
    does any one know if it possible to configure v4 universal driver to force the Account Track popup window when printing ?
    Tanks in adv,
  • kingarthur
    • 1297
    Re: Universal Driver v4 with Account Track Popup window
    I always tell customers to avoid V4, but I've just had a quick look at V4 I've just installed
    if you go to printing preferences, right at the bottom there's a line that says "please select model in "Device settings)" when you click on that, and then the model, there's a few extra bits. Haven't currently got a device with account track/user authentication on it
    • gavrielx
      • Oct 2015
      • 57
      Hi,
      tank's for your fast reply ,
      unfortunately i can't found it there.
      Regards,
        • 29332
        Use the. kX driver
        • gavrielx
          • Oct 2015
          • 57
          Use the. kX driver
          kX is not for Kyocera machines?
          Regards,
            • 29332
            Regards,
            It's the recommended driver for all Kyocera installs
            The V4 is not
