KONICA MINOLTA C258-C308 firmware
  • M1963
    • Jun 2017
    • 54
    greeting,
    i need fiemware KONICA MINOLTA C258-C308 with support smb 2.0
    thank you
  • M1963
    • Jun 2017
    • 54
    Re: KONICA MINOLTA C258-C308 firmware
    does anyone know if this firmware for c258 A7PU0Y0-F000-GCK-X4(00) has SMB2.0 support
    • jotunn
      • 591
      As far as I know C308 series should work with SMB 2.0 "out of the box"...
      There's nothing special (repaired bugs/issues) in GCK-X4 firmware in relation to SMB 2.0 compatibility, so should work witout problems.
      • M1963
        • Jun 2017
        • 54
        thanks for your help,
        i have c308 with firmware 0100-G00-Q4 it works normally.
        I would like to try this firmware on c258 but I don't have it.
        if anyone has...
        • jotunn
          • 591
          Which language group do you need? The most popular EFIGS (English/French/Italian/German/Spanish), or other specific requirements?
          • M1963
            • Jun 2017
            • 54
            English
            • jotunn
              • 591
              Your firmware:
              The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
              • copier tech
                • 8095
                Originally posted by jotunn
                There is a later version available now, Q8.
                • tsbservice
                  Field tech
                  • 7904
                  C258 machine in question not latest i series
                  • jotunn
                    • 591
                    Sure, there is... however he said, that the other machine have got this version, so I assumed that this version will fit his expectations.
                    The next thing is, that I don't trust in fresh firmware versions - I saw too many bugs and strange behavior (missing national on-screen keyboards, not working AirPrint, authentication and so on...).
                    • tsbservice
                      Field tech
                      • 7904
                      Fyi, last one is GCK-X4.
                      Q8 - sure there is... but for other models
                      • Synthohol
                        Certified Konica Expert
                        • 5733
                        i have gch-x4 if interested.
                        lmk
                        • M1963
                          • Jun 2017
                          • 54
                          thank you for your support.
                          not sure what went wrong with the network card i had to restore the old version.
                          I still have a problem with SMB scan.
                          greeting
                          • rrrohan
                            • Sep 2011
                            • 1977
                            what error do u have when scanning
                            PC or Mac?
                            • M1963
                              • Jun 2017
                              • 54
                              server connection errortrying to connect to SMB 2.0 (PC)
                              hostname search does not see the host, other machines on the same network do
                              host and work without problems.
                              I checked all the network settings.
