Konica Minolta BizHub C3350: Scan to Folder stopped working
  • Distorted Vision
    • May 2017
    • 16
    The Scan to Folder function has stopped working on my Konica Minolta BizHub C3350. I have checked the permissions on the destination folder. I also tried following this guide:
    How to setup SMB scanning on the Konica Minolta Bizhub copier to scan to a Windows Share – Lyle Epstein's Systems Engineer Blog
    But I do not have Network->SMB Setting->Print Setting
    I only have
    I'm therefore unable to enter the Windows Workgroup which I think might be the issue.
    Can anyone help please?
  • allan
    RTFM!!
    • 5459
    Re: Konica Minolta BizHub C3350: Scan to Folder stopped working
    What is the detail on the error looking at the log on the machine?
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5727
      never use smb print, its a huge waste of memory.
      printing should be done on port 9100 by IP address, not antiquated protocols.
      why would you try smb printing, so it publishes the print queue in the workgroup?
      im sorry for being so adamant about it, its just i have fixed so many print issues over the years with simply using a proper static IP address.
      we are not in windows 98 land anymore
      • Distorted Vision
        • May 2017
        • 16
        Sorry, can you please tell me how to do that.
        • Distorted Vision
          • May 2017
          • 16
          I am not printing with SMB. I am trying to setup Scan to Folder.
          I was just following the steps in this guide:
          In step 8:
          "8. Now still under the SMB Setting, select Print Setting. Then in the Workgroup field enter in the NETBios Domain name or the Workgroup in CAPS. In this example my Server\Workstation is joined to a domain called PS. Then click OK."
          • allan
            RTFM!!
            • 5459
            Job log on the machine under sent items.
            Whatever
            • Distorted Vision
              • May 2017
              • 16
              This is what it displays. There is no error code:
              • asheer.singh
                • Jul 2023
                • 20
                This sounds like it's potentially an authentication issue with the SMB server. If it stopped working without any changes to the settings in the Konica Minolta, it could be due to recent windows updates that have stopped SMB1 and NTLM v1 due to security issues.
                I had this similar issue and was resolved with changing the SMB authentication type. Network settings --> SMB Setting --> Client Setting
                Change the SMB Authentication setting to NTLM v2
                Hope that helps
                • asheer.singh
                  • Jul 2023
                  • 20
                  Here is a screenshot of my SMB settings in the Konica Minolta:
                  • Distorted Vision
                    • May 2017
                    • 16
                    Hope that helps
                    Changing the SMB Authentication setting to NTLM v2 made no difference.
                    • Distorted Vision
                      • May 2017
                      • 16
                      [ATTACH=CONFIG]59120[/ATTACH]
                      The image is too small for me to see.
                      • asheer.singh
                        • Jul 2023
                        • 20
                        Where is your SMB folder hosted? What version of Windows?
                        • Distorted Vision
                          • May 2017
                          • 16
                          Windows 10
                          • asheer.singh
                            • Jul 2023
                            • 20
                            Windows 10
                            Ok. Try this:
                            On the computer:
                            Right click the folder being scanned to, Properties, Sharing tab, Advanced permissions. Add your dedicated scan user to the list if it is not here. Give Full Control. Double check the Security tab while in here.
                            Control panel, Program Features, Turn Windows Features On and Off, find SMB V1 and check it. Windows will set needed file and ask to reboot.
                            Make sure Network Type is set to "Private". Start, Settings, click Network, change the setting. Don't remember exact steps here.
                            • Synthohol
                              • 5727
                              you have distributed file system checked, is there a reason why?
                              its not typical.
                              also, have you tried to see what folders show up as shared from another computer?
                              if you cant see it from another PC neither can the copier.
