Fiery E100-06 Turn on the controller bizhub c364
  • CopierNerd
    • Feb 2015
    • 194
    Bizhub C364
    Fiery Model E100-06
    Error : Turn on the controller
    Changed the cables. Network Port light status is normal. Plugged the cable from fiery to the machine both cables ok showing data and communication.
    no ping.
    Without fiery it's working .
  • copyman
    Owner / Technician
    • Sep 2005
    • 4511
    Re: Fiery E100-06 Turn on the controller bizhub c364
    Originally posted by CopierNerd
    Bizhub C364
    Fiery Model E100-06
    no ping.
    Are you using crossover cable from Fiery to copier?
    Might need to reload system software. I should have software if you need it. PM me with your email.
    • Synthohol
      Certified Konica Expert
      • 5733
      the copier firmware or the interface board is the usual culprit
      does the LED say 00?
      can you access the fiery web page?
      can you access the copier 1 octet up?
      is the copier NIC set to DHCP?
      is the ip shown on the screen 172.24.249.2? or similar?
      does the fiery show in CWS?
      not the e model?
      • copier tech
        • 8095
        Bizhub C364
        Fiery Model E100-06
        no ping.
        To be honest on an old C364 if the client doesn't actually need it I would simply remove the fiery & use the onboard controller.
