Konica bizhub 458 internal error c 392b
  • DOE
    • Mar 2010
    • 258
  • Woxner
    • Jul 2011
    • 825
    Re: Konica bizhub 458 internal error c 392b
    Replace the fuser it could be bad wire according to code. Or if you did not turn off and plugged fuser in you may have blown mfp.
    C392B: Fusing sensor wire breaks detection (difference of temperature)
    Rank
    A
    Trouble detection condition
    The difference between the temperature corrected by the heating roller thermistor 1 (TH1) and the temperature detected by the heating roller thermistor 2 (TH2) exceeds a predetermined value.
    Trouble isolation
    Relevant electrical parts
    Fusing unit
    Heating roller thermistor 1 (TH1)
    Heating roller thermistor 2 (TH2)
    MFP board (MFPB)
    • Woxner
      • Jul 2011
      • 825
      Do the error reset properly. There is not a no to select. Hold reset down turn on machine. Wait for dot in screen. Touch trouble reset the turn off and back on. You can also hit system reset under systen 2
      • tsbservice
        Field tech
        • 7904
        Does the old fuser works if you put it back?
        As Woxner mentioned you may have bad luck getting defective new fuser.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4511
          Since you posted that you only removed the fuser and didn't replace with a new one I think that is where you should start. Or at least swap a good fuser from another machine.
          Of course try and reset the way wox posted by holding down reset while turning on.
          • DOE
            • Mar 2010
            • 258
