Konica-Minolta and Scan to SMB
  • i-have-fax-problems
    • Mar 2020
    • 98
    There was/is a Konica-Minolta document with the description how to set up Scan to SMB.
    Does anyone have it?
    I think, in this document, it is said that it must be a local user for scan to smb, a domain user will not work.
    Is this correct?
    We have a customer who only has domain users and scan to smb doesn't work with a C3320i.
    I'm not sure about it.
    Thank you.
  • Synthohol
    Certified Konica Expert
    • 5734
    Re: Konica-Minolta and Scan to SMB
    since the dawn of OCR scanning i have always setup a local user named scan with a pass of scan or Scanner01 if complexity is used.
    domain scanning is possible but i think the machine has to join the domain which eats a server CAL
    im still a big fan of scan to USB flash drive.
    • Kenny
      • Jun 2009
      • 515
      Attached is a guide on how to set up SMB scanning Scan to SMB v2.1.pdf
      as mentioned your best off setting up your own local user.
