bizhub C360 spots in color printing
  • computerfan3
    • Jun 2022
    • 5
  • tsbservice
    Field tech
    • 7904
    Re: bizhub C360 spots in color printing
    Where are samples of gradation or halftone of other colors?
    • computerfan3
      • Jun 2022
      • 5
      Now I made a new scan of all test prints!
      Best regards
      • tsbservice
        Field tech
        • 7904
        Clean IDC sensors x2 then do stabilization and check.
        • computerfan3
          • Jun 2022
          • 5
          Thanks for your help.
          I have cleaned both sensors and performed the stabilization. Unfortunately, the result is still the same as before:
          • tsbservice
            Field tech
            • 7904
            I would carefully play with transfer voltages in service mode. Read the manual before doing it.
            • computerfan3
              • Jun 2022
              • 5
              I am excited, the setting "2nd Transfer Adjust -> Plain - Color: 4" solved the problem!
              Thanks for the tip.
              Do you know which component this setting affects? Should I think about replacing a component?
              • Albonline
                • Sep 2008
                • 1131
                Thanks for the tip.
                This usually is due to humidity or lack of either in the paper or most likely the environment. component involved is 2nd transfer roller.
                • computerfan3
                  • Jun 2022
                  • 5
                  Thank you for the great advice!
                  I have now set the setting to +2 and a perfect result.
