Bizhub c458 C2152
  • Miltan
    • Apr 2023
    • 34
    [Error Code] Bizhub c458 C2152
    Got a case where the printer throws error code C2152. The instruction tells to open and close the hatch and after few seconds, it stops. Not the first time i've had to deal with such issue but this one is really stubborn. Usually replacing Fusing Drive Unit fixes the issue but even after replacing, it still gives the same error.
    What i've also tried
    -EXCB (No such issue on the other printer)
    -Transfer Belt (swapped from the other printer, still the same error)
    -Clearing the sensor where it's located inside the printer above drums
  • techsxge
    • Jan 2022
    • 660
    Re: Bizhub c458 C2152
    Have you consulted the Service Manual?
    • Miltan
      • Apr 2023
      • 34
      Yes.
      Fusing motor (M3) and 1st transfer and pressure clutch (CL5) was replaced in combination with fusing drive assy.
      I tried using air duster to clean 1st transfer pressure sensor (PS39) with no success. Might try that again.
      Expansion control Board (EXCB) was tested on different machine and it didn't threw any error.
      Still leaves me with MFP Board (MFPB) but i find it hard to believe this could be the cause.
      • techsxge
        • Jan 2022
        • 660
        Yes.
        did you do a trouble reset yet?
        • Miltan
          • Apr 2023
          • 34
          It's a rank B Error so it should automatically trouble reset when it detects. But indeed, i did trouble reset manually
          Edit: Man, i'm such an idiot. I forgot to put the piece of metal under green gear that's for releasing jammed paper. Such a nuisance and this was the cause. That's what i get when i try to test something and don't assemble the printer back. Anyway, the error went away once i opened and closed the hatch
