C558 error C3102
  • cube10025@gmail.com
    • Aug 2022
    • 55
    C558 error C3102
    Hello, some help with c558.
    When I do a reset, I can hear the machine grinding gears. The gears on the fuser are really hard to turn, and there is a white button on top. I am not certain what this does. Anyway, I am not sure if it's the fuser or something else. I can't find where to run the motor test in service mode. Can I run the motor test without the fuser?
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 296
    Re: C558 error C3102
    Remove the side covers of the fixing unit and you will see the gears. Almost 100% you will have one or more with broken teeth, that is the problem, and it is very common if the fuser is old.
    Field technician since 1994
      • Aug 2022
      • 55
      I did open it, did not see any broken gears, I will replace the unit, but I am afrid there might be broken gears in the printer.
      • tsbservice
        Field tech
        • 7904
        Replace the fuser and you should be good.
        • kingarthur
          • 1296
          you'll probably find the bearings/bushings on the cleaning roller have seized, it's a known fault - there was a mod on the earlier fusers, where the bushings were replaced with bearings. newer fusers already have the new parts
            • Aug 2022
            • 55
            Opend it and you seem to be right.
            Replaced the fusor, and it worked.
