Secure Print on a BH 300i
  • larweedad
    • 86
    I have a costumer that uses secure print. Their new 300i has storage and everything encrypted for BH Secure Healthcare. When they print using secure print, the copier says deleted due to error (login error). Firmware is G00 P8. The manual is helpless. What did I forget to change. We don t have a lot of BH Secures out. Thanks for the help.
  • Synthohol
    Certified Konica Expert
    • 5734
    Re: Secure Print on a BH 300i
    just a suggestion, will it allow you to crate secure boxes they can print to and release at the machine?
    • femaster
      • May 2011
      • 1458
      Did you remember to input the relevant information into the print driver so that the driver can authenticate to the copier? If that information isn't entered correctly, you will get a message like that on the copier. While I've never dealt with secure print, I'd assume it would be similar to something like account track where each user has their own credentials that need to be entered into the driver on their PC.
      • wjurls
        • Feb 2017
        • 490
        I'm seeing the same issue here at the school district with the new Accurioprint 2100's. Secure print just doesn't work. It works just fine on all our Pro 951's and 1100's, but not a single 2100 works.
        I can only get "save to user box" to work. This is a PITA because I have to manually enter every user box into the machine via the control panel. If I try to enter them through the web interface I get an "Invalid data" error. So frustrating when we have over 2,000 teachers in this district. I'm going to try using secure print while bypassing the network to see if that works.
        I will update this thread if I have any success as I suspect it's the same issue you are having.
        • larweedad
          • 86
          I found in security settings, prohibit settings. Secure print is unchecked. I set up a user box for me, works fine. The IT person sent a secure print job with 2 character user name and 2 character password. login error.
          • emujo2
            • Mar 2017
            • 1580
            Admin settings allow for Secure print to be enabled, when this is enabled the driver should ONLY allow secure printing, user box, proof ect should all be gone.
            Secure print can be used at the individual driver level as well
            None of it works if the driver and function verison of the MFP do not match..If the driver can't pull the info from the MFP (configure tab) then you lose all of this functionality. print jobs sent are deleted because the credentials are missing, none of the accessories are seen by the drver.
            • strider5555
              • Jun 2008
              • 96
              If you login to PSWC, does it show the correct model? Or is it showing generic? I had a C450i do the same thing with secure print. Print driver showed all the correct options enabled, but secure print login failed. Strange thing was that even though SoftwareSW 10 showed the correct value, which should be Hex 02, it was not recognized properly. Even after a clear all data. What fixed it was changing this switch to Hex 00 and rebooting, then reverting it to Hex 02 and rebooting again fixed our issue. Changing this setting will reset all network settings, so just be aware of that. I don't know what effect this would have with Bizhub Secure.
              • emujo2
                • Mar 2017
                • 1580
                Bizhub secure can be configured to auto delete jobs stored in the secure print folder. It's not common to find this enabled as secure print is not used very often. The config is not part of the HDD settings, but is part of the the user boxes setting.
                • wjurls
                  • Feb 2017
                  • 490
                  Ok, so here is what I found out today on my 2100. In order for secure print to work, the box now must be created on the machine beforehand. If a secure job is received without a matching box, the machine will ignore it. The machine will no longer create the box when a secure job is sent. In addition, in order to remotely program secure boxes, or user boxes on HDD. The password MUST be 8 characters or longer. You can still use less than 8 characters, but to do that, the box must be entered using the control panel of the machine. I tried to set less than 4 digits in admin mode under "security settings" but 8 is the minimum.
                  Keep in mind that the "i" series and production Konica's are completely different engines with different GUI's. They may have still applied the same security measures to both lines though.
                  • larweedad
                    • 86
                    Received a C250i and set it up for another costumer. No encryption and still no secure print, as the costumer wants it. Can not do ID and Print easily either. So I will have to explain to them to use user box instead. Can hear it now, that is not how we have been doing it, that is to many buttons, etc.. Thanks for the help.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      they arent Macs by any chance?
                      I recently had issues because I couldnt find drivers for C360i running macOS 14 Sonoma
                      EDIT: Strange i just checked the USA site and it has 14 drivers
                      </title>
                      <meta name="viewport" content="width=device-width, initial-scale=1.0" />
                      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                      <meta name="title" lang="en-us" content="Service | Self-Help Product Support" />
                      <meta name="description" lang="en-us" content="One Stop Product Support for Konica Minolta Products." />
                      <meta name="keywords" lang="en-us" content="Konica Minolta drivers, Konica Minolta utilities, Konica Minolta product documentation" />
                      <meta name="Author" lang="en-us" content="KonicaMinolta" />
                      <meta name="robots" content="all" />
                      <title>Self-Help Product Support | Konica Minolta Business Solutions, U.S.A., Inc.
                      but Australia site does not.
