No color on Macintosh (Sonoma 14.2.1) on Bizhub c224
  • dgregan
    • Jan 2024
    • 7
    Since upgrading to MacOS Sonoma (14.2.1) I am no longer able to print in color. There is no longer an option in the print settings that allows you to select Grayscale/Color. There is no application that allows color printing on my Mac. The printer is fully updated with firmware. My contract vendor has no idea what the problem is... no mac experience.
  • Synthohol
    Certified Konica Expert
    • 5731
    Re: No color on Macintosh (Sonoma 14.2.1) on Bizhub c224
    follow this guide and you cant go wrong. Mac: How to change default printer settings | Pirate Ship Support
    you will be able to see the default options.
    make sure the driver is correct.
    • rrrohan
      • Sep 2011
      • 1977
      looks like driver support stopped at 10.15 so not surprising some compatibility issues
      • dgregan
        • Jan 2024
        • 7
        Thank you very much for this information. I like the CUPS interface better than the Konica Admin. However, the color settings that are missing are not part of either configuration. They do appear in the Konica Admin panel, but have no effect when changed. I believe it is a driver problem and am not sure what to do.
        • dgregan
          • Jan 2024
          • 7
          Thank you very much for responding. I believe you're correct. The removal was in direct correlation to the OS upgrade. The setting was there and then disappeared. Neither Apple nor Konica have anything to say about it. It still functions properly on my wife's PC, or course...
          • allan
            RTFM!!
            • 5459
            Use the CUPS interface to install the latest PPD do not use the installer.
            Whatever
            • rrrohan
              • Sep 2011
              • 1977
              I didnt know u could bypass the OS version by just force installing via CUPs
              • dgregan
                • Jan 2024
                • 7
                Originally posted by allan;[URL="tel:2580532"
                2580532[/URL]]Use the CUPS interface to install the latest PPD do not use the installer.
                OK, I think I know what you mean and where to find it... Thank you very much for the input. Hopefully, I can come back with questions. Thank you, again!
                • dgregan
                  • Jan 2024
                  • 7
                  If you are able and willing, would you please help me figure out which of these files I should install using CUPS as you've described? Thank you very much, in advance, for your time and assistance.
                  Drivers & Downloads | KONICA MINOLTA
                  • dgregan
                    • Jan 2024
                    • 7
                    Well... I wish I could say that I knew what I did to resolve this. I suppose it might have been one more attempt to install the driver with a slightly different setting, but... either way, I'm able to print in color now.
                    Thank you all for your help and time. This place is a great resource.
                    • dgregan
                      • Jan 2024
                      • 7
                      I don't know how to close a thread, so...
                      • Synthohol
                        • 5731
                        im glad you got it to do color.
                        the problem is that model has been discontinued for a while so there was no need to develop newer drivers.
                        i had a customer install parallels on his mac and ran windows 7 in it and would print through that because no driver was avail for his version at the time.
                        just offering an alternative solution for a unsupported, discontinued model.
