Bizhub C250i FS-539SD jamming code J7225
  • copier tech
    • 8095
    [Jamming] Bizhub C250i FS-539SD jamming code J7225
    Hi all,
    As per the title we have this device in a church & it jams every time in the booklet maker with the jam code J7225 @PS12 (this sensor works fine.)
    I can't see any obstruction / stuck paper.
    There is a TAD (bulletin) on this issue, checking the gears are aligned correctly, which they are.
    Do any of you guys have any tips!?
  • Max
    • Oct 2011
    • 544
    Re: Bizhub C250i FS-539SD jamming code J7225
    Churches tend to be very damp places. There are a lot of relay rollers in the booklet finisher too. Wd40 them all and wipe dry, plus try a fresh 80gsm paper.
    • copier tech
      • 8095
      Yes I agree, first thing I did was new paper etc. It seems the issue is the paper is not being fed out of the booklet holding area to be folded etc.
      • Ziggy
        • Feb 2018
        • 676
        Is the paper weight set correctly. You could also try using an antistatic spray such as brillianize to clean the plates inside of the folding unit
        • copier tech
          • 8095
          It's not this simple, can't get a single fold / booklet to pass through.
          Seems like a drive issue but no errors to indicate this.
          • fntsy
            • Aug 2008
            • 26
            Hello, did you solve the problem? I have the same problem with FS-534
            • copier tech
              • 8095
              Yes, it was the front blade mount was cracked at one end so the blade / knife wasn't returning home level preventing the paper from passing.
