C554e All tray's cannot be used
  • PaperCut
    • Sep 2008
    • 21
    [Electrical] C554e All tray's cannot be used
    does everyone have seen this? I replaces MFB board, and SSD board, but still showing all tray unable.
  • PaperCut
    • Sep 2008
    • 21
    Re: C554e All tray's cannot be used
    so far i check the all wiring and it goes to PCRB, so i order the board. Guys let me if there any software SW for this.
    • allan
      RTFM!!
      • 5445
      Silly question. Did you check trouble isolation?
      Whatever
      • kingarthur
        • 1209
        Seems to be the easiest, and possibly the obvious choice
        • tsbservice
          Field tech
          • 7649
          Obvious things are usually in the manual, obviously nobody cares about manuals... that's why I care I'm not nobody I'm me
          • copyman
            Owner / Technician
            • Sep 2005
            • 4226
            Ouch! I've never seen every paper tray isolated. But there is a first for everything.
            Like others posted did you UNset the trays in service mode "isolation tab". Did you initialize the machine in service mode?
            Think you are on the right track with the PCRB. No software needed with new board. Maybe update firmware after board is installed.
            • PaperCut
              • Sep 2008
              • 21
              All tray's is "set" on service mode isolation tab, I initialize the machine and update the FW to GDU-M1.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4226
                Like I mentioned in previous post they all have to be UNset. This makes sense because it would be rare all trays would be isolated at same time.
                If they are all "set" then you don't need PCRB. Just UN set them all.
                • tsbservice
                  Field tech
                  • 7649
                  Ouch!
                  +1 to what copyman said.
