I have not been repairing copiers long, but this one has me baffled. This is a bh287 and as you can see in the picture there is a grey stripe on the leading edge of the page. This has been happening on and off with this machine for a while. I have only recently gotten involved with it. This first cropped up and a tech changed a drum for it and it cleared up. Then shorlty after they were having a blotch on the page. Turned out that there was actually a small chunk taken out of the drum coating. For this I replaced the drum and the developer. The developer was changed because the users of this machine said "that happened before the last fix too" and because I could not figure out what carved a piece of the drum, I changed it. Then we had a bit of bad luck. The new developer was toast. It was not printing in small diamond patterns across the page. You could see it on the developer roller. So we replaced it, and this grey stripe reappeared. But it does not happen on every page, ONLY on the first page after turning the MFP on. If you leave it powered up and walk away for hours, no grey stripe. But turn it off and then back on, first page has the stripe. There are also some fine lines perpendicular to the grey stripe and a thin fairly solid line that always runs the long way on the page, no matter what format you are printing in. Here is a summary of what all has been done.
1 two drums have been put in.
2 three developers have been put it.
3 2 other fusers have been tried.
4 the entire paper path has been removed and cleaned and reinstalled.
5 on a suggestion, both the high voltage boards have been swapped with a known good MFP. The problem has stayed with the original MFP.
6. This thing has been cleaned from the scanner down, twice just to make sure.
7. The problem happens on a copy, a print from a computer, a print from a USB, and also an internally generated report.
Does anyone have even a wild idea? At this point in time I am even entertaining aliens and Hail Mary's. I appreciate any ideas you may have.
