Konica Minolta C3070 Controller
  • Raed
    • Jun 2016
    • 5
    I have konica Minolta C3070
    When i update firmware version from (A9VE0Y0-00I1-G00-25) to
    (A9VE0Y0-00I1-G00-30) The Controller still unconnected
  • Synthohol
    Certified Konica Expert
    • 5734
    Re: Konica Minolta C3070 Controller
    check bit sw.
    • Raed
      • Jun 2016
      • 5
      I did that but it didn't solve
      Dipsw 40-7= 1
      • Ziggy
        • Feb 2018
        • 677
        Dipsw 40-7= 1
        first if changing Dipsw 40-7 didnt help make sure to change it back. second which type controller do you have? The Dipsw settings differ with each model. There are instructions with each controller that will tell you what the settings are
        • Ziggy
          • Feb 2018
          • 677
          IC-313
          DIPSW Setting(1) Plug the main body power cord into the wall outlet, and then turn ON the main power switch andthe sub power switch.(2) Enter Service Mode.Note:Refer to procedures in the Service Manual toenter into the Service Mode.(3) Touch the System Setting key.(4) Touch the Software DIPSW Setting key.(5) Set the following DIPSW.40-7: OFF(0)55-4: ON(1)(6) Touch the Return key and then touch the Exit[SERVICE] key.(7) Touch the Exit [UTILITY] key.(8) Turn OFF, then ON the main power switch andthe sub power switch of the main body.
          • Ziggy
            • Feb 2018
            • 677
            IC-417 is same as IC313
            . Set the following DIPSW settings.40-7: OFF(0)55-4: ON(1)
            • Raed
              • Jun 2016
              • 5
              Controller IC-605
              • Ziggy
                • Feb 2018
                • 677
                • Raed
                  • Jun 2016
                  • 5
                  Thank you for reply
                  The machine before update firmware working ok , but when i update firmware the controller unconnected
                  • Synthohol
                    • 5734
                    did you read the readme for that FW? maybe something there
                    flash back the version that it had before and see if it is indeed FW related.
                    id read the readme first. maybe the controller has its own update?
