pls help this machines was running fine until we changed black image and colour drive units.. it is now 600 copies later and this code has come up..has anybody had this on this machine..what must i look for.
Carry out your transfer belt Mod. Also reinforce the bracket.
CAUSE: In addition to the causes listed in the Service Manual (1st Image Transfer Pressure/Retraction Position Sensor, PC6; Main Motor, M1; the 1st Image Transfer Pressure/Retraction Clutch, CL3; and the Mechanical Control Board), check for paper stuck in the paper path. For example, paper in the fuser section could block a sensor causing the C-2152 code.
when you say you changed the drive units, are you talking about the units at the back of the m/c, if so...did you remove the fuser drive unit, on the C352 this also drives the transfer belt, if you've lost the spring from that drive unit, you'll get a c 2152 error
