How do you program default scan settings so it applies to all users? Using standard controller btw. I want to set the machine so that it scans in black and white only, by default it's on auto and users would have to change it to black every time. Thanks.
c450 set default scan settings
Hi. Thanks for the response but I followed what you said but I didn't see those specific options. When I got into Utility/Counter >> User Settings : #4 is Copier Settings #5 is Scanner Settings and even under scanner settings there are only 3 possible choice: Jpeg Compression, Black Compression, Scanner time-out. Is this due to a different firmware? ThanksComment
Shouldn't that be select current settings to change it to the new settings you have just entered.Comment
