Does anyone have a manuel for this machine that perhaps could give me a reference to the code I am getting.I sure would appreciate it. Thanks in advance.
KM Bizhub C6500 Error code C0213
Paper exit issue
Paper
exit
abnormality
C-0213 After the paper exit pressure
sensor (PS10) turns OFF, it is not
turned ON within the specified
time.
AC drive board (ACDB)
Printer control board (PRCB)
Paper exit motor (M54)
Paper exit pressure sensor
(PS10)
Are you trained on this box? If not, i strongly suggest you to get a GOOD technician. These are Production Printing Mashines, not those fluffy tingletangle color office Boxes. They work very well, if correctly handled, but they will bite you in the arse if you are fumbling around not exactly knowing what you are doingIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions! -
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
Paul@justmanuals.comComment
C-0213 (C0213) code intermittently.
Solution
PROBABLE CAUSES:
1.A one-way paper exit drive gear is slipping.
2. Dirty or failed photosensor.
Clean or replace PS10 as necessary
3.Older style regulating shaft is installed.
HTHColor is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
Had this code many times now, every time it turned out to be a slipping paper exit drive gear ( situated under small cover on exit assy on L/H side of machine) removing gear cleaning shaft and bearing inside gear always has resolved problem.Comment
oce_cannon
Re: KM Bizhub C6500 Error code C0213
Do you have a picture of where this gear is ?
ThanksComment
Im having this same error. The paper is not getting through the fuser yet and no where near the exit rollers. Its getting held up before the roller near where the paper comes in and touches the transfer belt.
Seems like a motor or the board?Comment
Okay i found the real problem, there is a coupling that runs the exit roller if that coupling is even slightly misaligned it will throw out an error. i wish i had a picture of it. maybe in the parts book i can show you guys what to look for.
Parts - A03U 8617 01 COUPLING /1
and A03U 8631 00 Coupling /B
Look in the paper exit Guide of the manual
OMG!! after changing these two item the machine never stopped!!! Paper would feed crooked and kept goin! I was surprised after changing these parts made a big difference!!
but also make sure the exit guide one way bearing is good as well!
Good Luck!Comment
Good Luck!
Do you think its anything near the exit roller? The paper is still miles away from the exit area when I get this error?Comment
