I have a problem with printing double sided with konica minolta di2510. When I use the copy function, the double sided option is available, but when I print from PC, in the properties window of the printer, the "duplex/booklet" option is in "off" position, and the field is gray so I cannot select "on". Any suggestions?
how do I print double sided with Konica Minolta Di2510???
