Bizhub C353 boot up problem
  • AjitN
    • Mar 2009
    • 287
    Hi
    I have one C353 which displays only Sand Glass after power ON. Machine rotates but nothing happens further.
    Reloaded firmware still same symptons.
    Any known solutions before testing MFP board, Power supply unit.
    Thanks & Best Regards
    Ajit
  • pinoyprinter
    • Mar 2011
    • 17
    i think its an nvram malfunction.
    • stevelau
      • Jul 2010
      • 21
      Try changing the NVRAM. If still cannot, try to flush out the firmware and reload.
      • bhangdu
        • 16
        I had a same problem, i have run the nvram recovery special firmware on the machine
        • AjitN
          • Mar 2009
          • 287
          Thank you friends.
          I do not have nvram recovery special firmware tool. Does it named as "A02E0Y0-F000-GCQ-J8_00_.EXE".
          If this is the file I have it but if not, can anybody tell me where to find the same.
          Best Regards & Thanks again
          Ajit
          • bhangdu
            • 16
            [Release version]
            <C650/C550/C451/C353/C253/C203 jig firmware>
            Model
            Program Name
            Ver.
            Program File Name
            Checksum
            Note
            bizhub C650
            Jig firmware
            GCQ-J8
            A00H0Y0-F000-GCQ-J8(00).EXE
            0E9A
            bizhub C550
            Jig firmware
            GCQ-J8
            A00J0Y0-F000-GCQ-J8(00).EXE
            8E57
            bizhub C451
            Jig firmware
            GCQ-J8
            A00K0Y0-F000-GCQ-J8(00).EXE
            7D69
            bizhub C353
            Jig firmware
            GCQ-J8
            A02E0Y0-F000-GCQ-J8(00).EXE
            91B0
            bizhub C253
            Jig firmware
            GDQ-J8
            A02E0Y0-F000-GDQ-J8(00).EXE
            9139
            bizhub C203
            Jig firmware
            GEQ-J8
            A02E0Y0-F000-GEQ-J8(00).EXE
            AFA0
            Cheers
            Abhay
            • AjitN
              • Mar 2009
              • 287
              Hi
              Problem is resolved by nvram initialization.
              Thanks and best regards to all
              Ajit
              • Mike Lee
                C253 Planets screen
                Ineo C253 planets showing.
                Flashed firmware.
                Tried Memory chips.
                NVRAM ok.
                MFP pcb changed.
                Still same fault.
                Changed PRCB PCB and flashed firmware again and now finally works !
                • bizpodcentre
                  Re: Bizhub C353 boot up problem
                  Hi,
                  I also have the same problem but on Konica Minolta Bizhub C253. Does anybody
                  have the NVRAM recovery file for bizhub C253? You can email the file to me
                  at bizpodcentre@yahoo.com
                  thanks
                  • mervyn
                    • Jul 2011
                    • 90
                    As previously ststed on various posts here , if you are a trained konica minolta tech you can get the firmware on the kmbs tech website , if not then call a trained tech . No one is going to e mail you the nvram recovery program , it is against kmbs policy .
                    • ahson1989
                      • Aug 2017
                      • 23
                      Hi. I need bizhub c 203 frimware. Also tell me how to upload the frimware. I m new in this . Thnx
