BizHub 350 scan directly to PC
  • Davidhkii
    [Misc] BizHub 350 scan directly to PC
    Is this possible? To NOT go through a network but to go directly to the computer, like in the olden days? If so, how do I do it? Looks like the only USB port on the thing is for using the 350 as a printer. thanks.
  • ck1
    • 485
    yes! using ftp or smb scan
    • aleksander
      • 378
      The answer is "NO". You must connected to the network if you want to use the MFP as a scanner.
      • aesthetics1
        • May 2010
        • 148
        You should be able to set up TWAIN scanning with the TWAIN driver if the hard drive is installed in the machine. I believe you can do this over a USB connection.
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          cross over cable and set up the network settings then smb scanning.
          • emujo
            • Jun 2009
            • 3009
            Mr Spock is correct...2 NICs connected together is a (very) basic network. As long as the IP scheme is configured correctly for both MFPs, you should be able to set up SMB, FTP scanning and printing. Emujo
