Bizhub C253 --- Modem Unit error.
  • freixi
    • May 2009
    • 53
    [Error Code] Bizhub C253 --- Modem Unit error.
    Hello,
    I have a problem from Bizhub C253 .. in the display have message for Unit modem.
    please turn on the modem unit
    My problem is.. no have Modem unit instaled in the mashine.. no have Fax board FK-502 instaled..
    Is it possible to disable this? I find nowhere in the service mode one function to disable it. Then comes the problem that I have the HDD if I activate a erro and the memory is at 0% .. It is also not possible to come in to service mode. Please help ..
    Many thanks in advance.
  • freixi
    • May 2009
    • 53
    Re: Bizhub C253 --- Modem Unit error.
    Hi,
    problem from HDD ist resolverd.. HDD not Formatet
    unic problem:
    the last problem is the Modem unit disablen.. its this possible?
    best regards
    • tech51
      • 846
      Go into tech rep, press the csrc button, press id and input 1234567,press id again. Find the ram clear button and select that and exit out. Re-boot the machine. That should remove the message...
      • freixi
        • May 2009
        • 53
        Hello
        thx for reply..
        the csrc button is.......?
        woh ist the button?
        best regards
        • Taminol
          • 171
          We just took one of these over in Service and had exactly the same problem. Your procedure worked perfectly and saved me trawling through the service manual....cheers
          • habik
            • 2013
            Originally posted by freixi
            Hello
            thx for reply..
            woh ist the button?
            best regards
            It is the Remote Connection through GSM.. if I remember correctly Customer Service Remote Care
            I think.
            Firmwares HERE
            • raveendrala
              • Oct 2016
              • 78
              Thank you
