c220 scan to flash disk
  • bkamoga
    • Oct 2011
    • 31
    Dear all, l have a problem
    could any one know the steps of how to scan to
    the flash disk on the c220, becz apparantly l can only
    print from the flash my MFP doesnot print using the net work port
    and the USB
  • ineo+6501
    • Mar 2010
    • 262
    Re: c220 scan to flash disk
    If you are saying you want to be able to scan to a USB memory stick, you need to enable the function in the admin section. These models come out of the box with only the print function enabled.
    From the top of my head:
    Press Utility/Counter
    Touch Administrator Settings
    Press 12345678
    Touch OK
    Touch System Settings
    Touch User Box Settings
    Touch External Memory Function
    Set Scan to External Memory to Enabled
    Job done and you should now be able to scan to a USB stick
    • bkamoga
      • Oct 2011
      • 31
      Thanks 4 the reply but on the machine l dont see
      two fuctions 1. Touch External Memory Function
      2. Set Scan to External Memory to Enabled
      what should i do any reply
      and if possible padon the the steps
      thanks
      • emujo
        • Jun 2009
        • 3009
        "Ineo" is correct on the steps (wish he wouldn't post passwords though). When you plug the USB drive in you should get a pop up on the screen asking what you want to do...by default, you will only see "Print from USB Drive". If you are seeing this popup, then you are not following the steps correctly. If you do not see the option to enable scan to usb and send to user box, you may have a HDD issue, not installed, turned off, etc, but this would be unusual as the C220 comes with the HDD installed. If you touch the user box hard button, do you get the next screen, or a "beep". Beep would be a quick indicator that HDD is not present (physically/electronically). Emujo
        • kingarthur
          • 1296
          KM only recomemnd a max 4gb stick when scanning & even then not all sticks work, if they are using "separate scan", you will probably need to fit an HDD
          • habik
            • 2013
            Just to be sure Do you have to have it in Fat or Fat32 in order to get it going// I don't remember.. or it actually does not matter?
            Firmwares HERE
            • redhotrob
              • 69
              Also make sure that the stick doesn't have U3.
              U3 - Wikipedia, the free encyclopedia
