C253 Scan to Email always asks for "From" Address
  • Solotime
    • 223
    Is there a way to enter a default "From" address so the customer does not have to pick a from address everytime they want to scan to email? Other machines I am familiar with scan to email settings on have a default address you can put in so it will not require an entry each time.
  • JR2ALTA
    • Feb 2010
    • 2027
    Re: C253 Scan to Email always asks for "From" Address
    In the Administrator settings, fill out the two fields in Administrator Registration
    • habik
      • 2013
      As above, I usually use
      ScannerC253
      scanner253@localdomain.xxx
      Firmwares HERE
        • 22917
        There are two places. You'll need to enter the scanners sender name: scanner@domain.com and the administrator email address: administrator@domain.com
        • JR2ALTA
          • Feb 2010
          • 2027
          A purely subversive suggestion is to make the name that of that model.
          For instance instead of "copier@copytechnet.com" make it "bizhub@copytechnet.com"
          Can't hurt, eh?
          • RRodgers
            • Jun 2009
            • 1950
            For a few years we would have the copiers send us an email if there was a problem, we track everything via serial number so in the IPP section of the copier I would put serial number@customer's domain. So that way the ladies at the front desk would know if a copier needed service what copier it was just by looking up the serial number in our system. Made life pretty simple. I can't tell you how many times we've called a customer to let them know that we know your copier is on the frizt and we are on our way to fix it. Many times before the customer even knew there was a problem.
            • habik
              • 2013
              That was the main purpose of it at the first place I believe
              Firmwares HERE
                • 22917
                By the way, don't get crazy with the device email address. The administrator email address must be a real valid email, and the device email address cannot be excessively long. I don't know what the character limit is, but I got one working by abbreviating a very long email address. =^..^=
                • morpk
                  • Oct 2010
                  • 97
                  Hi i have seen this happen before when you set the admin and device email under the admin setting it doesn't update
                  go to fax/scan- communication settings- email address settings - admin email select the email,
                  then make this the machine default:
                  utility/counter- user settings fax/scan defaults current settings
                  try that hope it helps
                  • copier tech
                    • 8095
                    • Hansoon
                      • Sep 2007
                      • 3347
                      And I believed being the only one here still having two of these beasts out in the field...
                      Both are rentals and as long as they go, customers are happy and we still having loads of parts for them, why not?
                      Hans
                      “ Sent from my Intel 80286 using MS-DOS 2.0
                      https://www.copytechnet.com/images/smilies/biggrin.png
                      • avecosat
                        • Jun 2012
                        • 303
                        I also have some still working. last week I had to change a laser to one of them. LOL
                        • copier tech
                          • 8095
                          Wow not sure i'l splash out on a laser!. Most likely i'll just swap the 3 series out for a 4e etc.
                          • Hap
                            • Jan 2017
                            • 31
                            think i have cases in past where both were set i believe u had to go in and disallow user to change from address
