No response from touch panel on Bizhub 250
  • axyun
    • Aug 2007
    • 1323
    Bizhub displays all screens when buttons are pressed but when touching selections on screen there is no response or beep. Tried touching around selections and various parts of screen but nothing. I was at customers office for tray 1 feed problem and after servicing pickup unit customer mentioned touch screen problem. I did not have manual with me for touch screen calibration but don't know if I should expect that to work if I get nothing from screen no matter where I touch.
    I am thinking will need touch screen of board or complete unit. Any advice is appreciated very much. Frank/ActionPhotocopy
  • MAD0RAM
    • Oct 2012
    • 82
    Re: No response from touch panel on Bizhub 250
    We have had a few that cleaning the ribbon cable and reseating the connectors help this problem.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      Try taking the corner of a piece of paper or business card, and slide it under the panel edge and move it all the way around the screen cleaning any dirt from around the screen. I have seen where dirt or even a staple gets under the edge and puts pressure on the screen causing it to be unresponsive.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • axyun
        • Aug 2007
        • 1323
        Thanks for advice guys. If i have no luck with your tips and if it doe not calibrate does that mean I only need display panel or might I need whole control assembly? All the key outside the display work fine. Frank
        • Hansoon
          • Sep 2007
          • 3347
          Frank, you need only the touch panel. We have them:
          Drop me a mail:
          touchpanel[at]rex-technika.com (replace [at] with @ cause of the spammers here)
          Hans
          “ Sent from my Intel 80286 using MS-DOS 2.0
          https://www.copytechnet.com/images/smilies/biggrin.png
          • kingarthur
            • 1296
            Press the "accessibilty" button, this takes you to the touch panel adjustment, its worth a try, i've had to carry out the procedure up to half a dozen times before it works properly
            • Hansoon
              • Sep 2007
              • 3347
              Some background info:
              Hans
              • axyun
                • Aug 2007
                • 1323
                Thanks again Hans. Thanks to all. I called customer to explain about touch panel problem and he said it was working now. He said he was monkeying around with it and disconnected a couple of things and pulled plug. He said he then rebooted(turned on?) machine and then his touch panel was working again.
                what do you know...a new fix for touch panel problems. Best to all. Frank
                • Hansoon
                  • Sep 2007
                  • 3347
                  Will last maximum 14 days Frank. Panel is definitely bad. Went through this with so many machines. Not only KonicaMinolta but also KyoceraMitas, not to mention Ricoh and the others.
                  Good luck.
                  Hans
