Bizhub 420 with pcl xl error
  • SAR
    • Jul 2009
    • 199
    Having this issue on a biz 420 printing. The machhine prints out a blank page with the message pcl xl error in the upper left corner. It also says error:Illegal Operator Sequence, Operator:Read Image.
    Have replaced the MFP board/NIC, loaded a postscript and a new pcl driver, yet they say they are still having issues.
    Would a hard drive or more memory help? Trying to see if anyone else has seen this problem?
  • mo0651
    • 1054
    Re: Bizhub 420 with pcl xl error
    Make sure firmware is up to date. And check your driver versions. What is the O/S on computer?
    • Synaux
      • Mar 2012
      • 1224
      As mo0651 said what OS, but also is this happening only on one computer? Do you have a laptop or another computer that you can try out?
      (I would wager he is using Vista...lol...)
      • SAR
        • Jul 2009
        • 199
        Just wanted to say thank you for the replies. The problem ended up being a faulty network switch. The problem had been interrmittant, but was constant when we returned and it was easy to track down.
        • aleksander
          • 378
          Try PS Driver
