Configure SMB on Bizhub C253
  • ViktorD
    • Jul 2025
    Hi,
    I'm trying to configure SMB on a Bizhub C253. I don't know if this is a valid configuration so my apologies if I'm doing this completely wrong.
    I have configured Network --> Client Setting:
    SMB TX Setting = ON
    NTLM Setting = v2
    User Authentication(NTLM) = ON.
    I have also configured Store Address --> Address Book --> Store Address --> Created a new SMB registration with the following settings:
    Direct input = 6
    Name = SMBScan
    Host Address = my.windows.domainname
    File Path = dfs01\common\scan
    User ID = scanuser
    Password = xxxxxxx
    When trying to scan I'm getting an error message, "Folder not found". How do I solve this? I'm guessing that this scanner model is not able to handle DFS correctly but I'm not sure.
  • KalEl
    • Jun 2011
    • 35
    Re: Configure SMB on Bizhub C253
    Hi,
    What version on Windows are you using?
    I'd go for the easiest setup to get it tested and then build it up...
    Go on C: Drive. Create a folder called "SCANS".
    Right Click and share this giving full rights.
    Open Command prompt and type "net config workstation"
    Get the computer name (this is the host) and the username.
    So if I was creating one for Joe Bloggs... It would look like this...
    (tick main and applicable alphabet location)
    Tick Host
    Host: JOESPC
    File Path: SCANS
    Username: joebloggs
    You may need to open the port in windows firewall. So create an exception.
    • ViktorD
      Hi,
      The file server is running Windows Server 2008 R2 SP1.
      Setting this up on a local Windows 7 PC with an local account works great.
      I first thought I got this error message because it didn't accept domain credentials but if I write a completely incorrect password I get an different error about wrong login so I guess that means it can login and that the "Folder not found" error happens because of some other reason...?
      • KalEl
        • Jun 2011
        • 35
        Hi,
        Currently having a windows 2008R2 nightmare myself...
        Can you browse to the folder using another PC, to rule out a sharing issue?
        Here is a few things I've found maybe one will be of use to you...
        http://www.copytechnet.com/forums/co...-scanning.html
        Thank you for visiting the blog of...: Kyocera Multifunction Printer – Scan to Folder Feature
        Good luck and hope you find a solution.
        • ViktorD
          Yes, browsing the share using the specified scanning account on my local PC works great.
          The first two threads don't apply to my scenario at all even though i tested the suggestions and the last thread didn't help since the machine don't accept the changes becouse of invalid characters.
          Do anyone else know a solution to this?
          // Viktor
          • ViktorD
            Okay, so I finally solved this. The machine don't support DFS at all. So first you have to write the name of the file server and not the DFS-root path. Second, using my example above, you can't use the DFS-path either(dfs01 above), so the correct configuration compared to above would look like this:
            Direct input = 6
            Name = SMBScan
            Host Address = my.fileserver
            File Path = common\scan
            User ID = scanuser
            Password = xxxxxxx
            // Viktor
