I have a c364 that gives a jam code 93-10. This is a duplex problem only and it is intermittent. I have to run approximately 40 copies before
the problem occurs and then it it occurs every 15 or 20 copies. There is usually three sheets in the paper path when it jams. One at exit, one entering
fuser and one in duplex path. The duplex feed clutch has been replaced. anyone had this problem?
