Have a new machine has been getting this code since it was installed. Page goes through makes the copy but then indicates j66-14 after. Lift the lid and lower it and it clears. It's an exit jam. exit sensor checks out ok in I/O mode swapped it anyway with no luck. Before read sensor checks out in I/O mode. Exit motor is obviously working. Called Konica and they suggested replacing the df control board, that has been done with no change. Also re-seated all connectors from df to main body. Anyone seen this or have an idea of where to look next?
Bizhub 654 jam 66-14
Re: Bizhub 654 jam 66-14
There is a bank of 3 sensors located under the jam access cover towards the front of the MFP. We started seeing jams caused by these sensors getting stuck in the access cover cutouts. Install a piece of mylar that tends to push the sensors down about 1mm or so. EmujoAttached FilesIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals. -
Paul@justmanuals.comComment
I think I understand ... but what is "flaffed"?
I think I might be flaffed right now ... =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
