Bizhub 363 - Can not print config and demo page.
  • Nelo
    • Apr 2025
    Got this bizhub 363 in my workshop, its currently not printing prints from PC or even the config page. It can copy and you can print counter list. I changed RAM and HD, but still remains. I upgraded firmware and still the same. When printing from pc, the data light blinks but no print out. Need assistance here, I'm suspecting a faulty print control board can any one confirm or have I missed one setting.
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Bizhub 363 - Can not print config and demo page.
    check the network settings and see if there are restrictions in the admin section.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
      • 22917
      When authentication is enabled those buttons disappear. =^..^=
      • RRodgers
        • Jun 2009
        • 1950
        Pretty sure I had this on a C450, it was the NVRAM.
        • wseyller
          • Sep 2012
          • 1129
          Did you look in the job list to see if the print jobs show up? If so what is the error. Do you have account track/user auth turned on?
          Sent from my Galaxy Nexus using Tapatalk 2
          • Hansoon
            • Sep 2007
            • 3347
            Can you ping the beast?
            Hans
            “ Sent from my Intel 80286 using MS-DOS 2.0
            https://www.copytechnet.com/images/smilies/biggrin.png
            • JustManuals
              • Jan 2006
              • 9865
              Paul@justmanuals.com
              • emujo
                • Jun 2009
                • 3009
                Go into network settings, turn TCP/IP off, cycle power. Go back in, turn TCP/IP back on, cycle power. Go back into TCP/IP, set/verify your IP info. This does a kind of soft reset on the NIC. I've had little quirks like this resolved by doing this. If, when you go into Utility/Counter, the user settings and admin buttons are missing, then you have a job that for some reason is stuck in the queue, could be a corrupt fax also. Emujo
                • Nelo
                  Thanks, was able to sort out the problem. The Print Controller setting in service mode was at Controller2 I changed it to controller 0 and it worked fine.
