Konica Bizhub C253 Network settings disappeared
  • Doug James
    • Jan 2012
    • 935
    Weired, The customer said one day that they stopped being able to scan. They have a rip attached to this machine and it is acting like it is communicating with the machine but it isn't. Under administrator the network setting button is gone. Is it a licensing issue or something like that.
    • 22960
    Re: Konica Bizhub C253 Network settings disappeared
    Let's start with:
    What type of scanning?
    What OS?
    What settings?
    We'll need just a little more to work with. =^..^=
    • Doug James
      • Jan 2012
      • 935
      Let's start with:
      What OS?
      What settings?
      Sorry, The Administrator settings says it should have a network settings button and it doesn't show one. (Thinking that is the crux of the problem) The customer workstation can't scan from the copier to their workstation. Think they are running windows 7 but not sure. I sent a computer guy over their and he couldn't fix it. (I am not very computer savy) The customer hired another computer tech who called me. Since one of my customers I am doing all I can to help.
        • 22960
        So far you've only ruled out scan-to-email. =^..^=
        • Doug James
          • Jan 2012
          • 935
          I will get some more info on this tomorrow. They are an add agency and use scan to copy pictures to manipulate on their workstation. I think that is what they are having problems with. If I remember right they can print to it actually. I am really over my head here but it is stuff I need to learn... Thanks so much for your feedback
          • lanierboy
            • 149
            Hi,
            If you have a Fiery rip fitted to the machine then the standard network settings in the admin menu will not be there.
            you need to click on the (i) icon on the front screen of the copier and this will open the fiery menu.
            from there you can select print pages>config page and find all the details you need.
            hope this helps
            • Doug James
              • Jan 2012
              • 935
              Originally posted by lanierboy
              Hi,
              hope this helps
              It helps alot Thanks so much !!!
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 254
                Hardrive is not installed or not turned on and formatted. Requires two types of format. When not installed
                no scan functions or net settings will appear.
