bizhub c-220 scan to Email
  • acsolutions
    • Jun 2010
    • 519
    [Misc] bizhub c-220 scan to Email
    Hello,
    trying to set up scan to Email,but cannot! log into the admin mode in the browser and on the network tab then looking for Email tx on left hand side, not listed is there something new or is something missing?
  • Dougtech
    • Apr 2011
    • 113
    Re: bizhub c-220 scan to Email
    does the machine have a hard drive? Is it set to INSTALLED in the service mode?
    Without either of these set it will not even go to the scan screen if SCAN/FAX is pressed
    • B0265
      • Jan 2007
      • 718
      If you are using Internet Explorer 10 try the compatibility view.
      • acsolutions
        • Jun 2010
        • 519
        I checked for a hard drive and did not see one installed, I set up ftp in the mean time and I guess that answers your question about the scan/fax button. I dont think you need a hard drive to scan to Email, do you?
        • acsolutions
          • Jun 2010
          • 519
          I can access the machine from the browser,no problem! the only problem is the Email button on the network tab of the admin mode is not available!
          • Mr Mc Wilson
            Are You logged in to ADMINISTRATOR mode or are you logged in as Public user?
            You only get access to these options when logged in as Admin.
            • B0265
              • Jan 2007
              • 718
              This it how it looks in IE11:
              "Normal" view
              Compatibility view
              • Nelo
                does the machine have a hard drive? Is it set to INSTALLED in the service mode?Without either of these set it will not even go to the scan screen if SCAN/FAX is pressed
                Had a similar problem on the same model, after installing HD and doing the HD setup the scan/fax button became active and email scan worked ok. Try have a HD installed and setup it should work.
                • emujo
                  • Jun 2009
                  • 3009
                  You have "scan to Email" disabled in admin mode. Log into ADMIN at the control panel, turn scan to email on, then recheck your browser settings, you should be able to access the smtp setup. Emujo
                  • acsolutions
                    • Jun 2010
                    • 519
                    Yes
                    • emujo
                      • Jun 2009
                      • 3009
                      Another thing I would try is a different browser, Firefox, or Chrome. The update to IE 10 was automatic and KM was blindsided by it. The PS web Connection does not work well with IE10. Compatibility mode usually fixes the issue, but I guess not always. Emujo
                      • acsolutions
                        • Jun 2010
                        • 519
                        Sorry guy's it's a c-200! Sorry! I did check admin mode for scan to Email settings there was no enable/disable setting! I even printed a log to be through and did not see anything! Thanks
                        • doinbox
                          • Jan 2013
                          • 107
                          You can't scan to email without a Hard Drive. Where would the copier store the PDF before it sent?
                          • wseyller
                            • Sep 2012
                            • 1129
                            I know that the C450 can scan to email without a hdd but it will create a separate email for each page.
                            Sent from my DROID BIONIC using Tapatalk
                            • acsolutions
                              • Jun 2010
                              • 519
                              The machine is a bh200 not a 220, Sorry for the typeo! yeah, the machine doesn't have a hdd and its not even an option for this machine, just memory upgrade.
