Konica Minolta Bizhub c280 ITB Reset
  • Alex1
    • Oct 2012
    • 285
    Hi,
    is there is a way of Resetting the ITB for the Konica Minolta Bizhub C280. Thanks
  • hotfuser
    • 180
    Re: Konica Minolta Bizhub c280 ITB Reset
    Yes there is a reset. Once in service mode go to (counter) > (life)>(new Release)
    Open the front door
    Select transfer belt or fusing unit
    then press the start key.
    this will reset the ITB
    • rrrohan
      • Sep 2011
      • 1977
      Originally posted by hotfuser
      Yes there is a reset. Once in service mode go to (counter) > (life)>(new Release) Open the front door Select transfer belt or fusing unit then press the start key. this will reset the ITB
      open the front door first otherwise the start button wont change to blue and let you clear it
