I have a bizhub 363 that works perfectly except for when you try to send a print job to it from a computer. I have checked all the settings, re-installed drivers, and verified settings on the PC. What happens is that when a print job is sent to the copier, the data light starts flashing (locking up the keypad) and never prints. The print job cannot be viewed in the job que because the machine locks up but I can clear the data error in service mode which unlocks the machine again only to have this cycle repeat itself with each print job. Any help would be appreciated.
edit: I also brought my own laptop and hooked up to the network, loaded the driver with the same result as the customer. I did this to eliminate the PC being the issue. The customer has only one PC that prints to the copier (small account).
