Copying Colored Paper on a Konica Minolta C454e
  • Tonerjockey.com
    • Jun 2010
    • 41
    [Misc] Copying Colored Paper on a Konica Minolta C454e
    This isn't a huge deal but wondered if someone had a solution. I have a customer that frequently makes b/w copies of documents that were printed on colored paper. Her old copier had "a button" that would automatically eliminate any background from the colored paper of the original. I thought I could just adjust the contrast or something and get the machine to produce 2-bit b/w and then save it as a program, but I can't seem to figure out a combination of settings to eliminate the background.
    The best combination so far is:
    Original type is Printed photo.
    Brightness maxed out
    Sharpness dropped to lowest setting.
    Any suggestions?
    Thanks,
    Nate
  • wseyller
    • Sep 2012
    • 1129
    In the application menu there is a background removal feature.
    • TheOwl
      • Nov 2008
      • 1733
      Re: Copying Colored Paper on a Konica Minolta C454e
      Yeah, definately use Background Adjust to get rid of the coloured back ground.
      When you are in there, select "Discoloured Paper" and then lighten it off. Once you are happy with the output, save it as a Program and if they use this feature alot, you can then make a shortcut on the main menu.
      • Tonerjockey.com
        • Jun 2010
        • 41
        Yeah tried this in every setting and combination. It didn't work either.
        • TheOwl
          • Nov 2008
          • 1733
          Try doing the following and then attempt the Background adjust again:
          • Menu
          • Utilities
          • User Settings
          • Copy Settings
          • Default Settings
          • Factory Default
          You will then of course need to setup your standard defaults again such as default to B&W and double sided options if you use them as a default.
          • wseyller
            • Sep 2012
            • 1129
            Me personally with certain originals I've had to do the background removal two or three times by copying the copy. Then doing text enhancement to bring the text back to a good density. Of course it isn't practical when needed often.
            • Tonerjockey.com
              • Jun 2010
              • 41
              After playing around with it further I finally figured it out. Apparently I just didn't get all the right settings at the same time.
              SOLUTION:
              • Set Sharpness to Maximum
              • Set Contrast at Maximum
              • Set Copy Density at -2
              • Set Page Discoloration at Lowest setting.
              The only thing is that the settings will change according to the darkness of the colored paper original. If the customer uses a lighter paper then the text will break up and probably the Copy Density will need to be adjusted upwards. If the customer uses a darker colored paper original, the Copy density will have to be lightened. Otherwise this worked pretty well.
              Nate
                • 22916
                That's what those buttons are for, to fine tune the settings for each challenging original. =^..^=
                • Tonerjockey.com
                  • Jun 2010
                  • 41
                  I realize that I left something out there. I created a program button for the customer with those settings but told her that different colors of paper would give her different results. I just didn't want someone to try those settings and wonder why they were getting varying results.
