Animation Guide Data File
  • michael_braunstein
    • Feb 2015
    • 29
    I am in need of Animation Guide Data File for a Konica Minolta C454e not a C454 which appear to be different. If anyone would help download this file ASAP I would appreciate it. Thanks, Michael
  • copier tech
    • 8096
    Re: Animation Guide Data File
    I can send it to you for a small fee, it is a large file, about 600mb
      • Feb 2015
      • 29
      The file for the C454 is around a Gig. in size. Not sure about the C454e? Please make sure its for the "E" model and not the other which I already have. Small Fee, Sure just let me know how much. Thanks
      • wseyller
        • Sep 2012
        • 1129
        Just to add my 2 cents.
        The movie data file version 30 for the C454e is listed as 958.55 MB
        Filename: A5C10Y0-C000-G00-30 Movie(Function Version3).exe
        Works with C224e/C284e/C364e/C454e/C554e
        Check your PM
        • dc-master
          • Jul 2015
          • 39
          Hi
          I forced to use "clear all data" function in service mode and now "No Animation Guide available. Contact your service rep" is appear on screen.
          I have C364e and need the guide file.
          Can anyone send me?
          in Service Menu -> System 2 -> Install Data, I saw 3-4 line (Voice, Movie , OCR & ...)
          Will I need anything else to install (except animation guide)?
          • copier tech
            • 8096
            After an all clear the HDD is unset. All you need to de is enable it & load just the movie file.
            • dc-master
              • Jul 2015
              • 39
              I already enable it but how I should load the movie?
              • dc-master
                • Jul 2015
                • 39
                May you give me more hint?
                • copier tech
                  • 8096
                  Yes now install the movie data
                  • dc-master
                    • Jul 2015
                    • 39
                    I understood your answer but how I should do that?
                    When I'm going to "Install Data", The machine couldn't find movie file on hard drive?
                    only looking for files on USB
                    • copier tech
                      • 8096
                      Have you got the movie file in the root directory of your usb pen drive? & you can only install it from the usb port near the control panel
                      • dc-master
                        • Jul 2015
                        • 39
                        Thanks for your fast reply.
                        I don't have movie file on the USB.
                        As I wrote before, I did "Clear All Data" by safe mode.
                        you told me the movie file will remain on HDD.
                        therefore I should copy them from HDD to USB and then connect it to front USB port.
                        But how I should copy files?
                        • copier tech
                          • 8096
                          After you did an "all clear" the movie file is deleted, you'll need to download it, put it on a usb drive & install it in service mode.
                          The copier will still function as normal, you can ignore that message.
                          • dc-master
                            • Jul 2015
                            • 39
                            now I understand clearly.
                            How I can download the movie file? (from which web site)
                            I know that can ignore this message but I found a problem by scanning to user box and maybe it is related to this.
                            Also the machine without any error message is very better!
                            • copier tech
                              • 8096
                              You can only get this movie file from a KM dealer.
                              It won't cause any scanning issues, but that could be resolved by updating the main firmware, but again you can only get that from a KM dealer.
                              I agree seeing a red flashing light is not good!
