C224e paper jam 3003
  • avecosat
    • Jun 2012
    • 303
    Hi all , anyone have experience with this problem? I changed the M1, cl4, cl8, PS1 and PS3 and still the same problem .Thanks
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2140
    Re: C224e paper jam 3003
    does the registration roller turn freely or is it tight ?
    Once they tighten up you will get all kinds of jams occuring.
    happens anywhere from 300k upwards depending on the environment
    • hotfuser
      • 180
      if the copier is at a high volume try checking the registration actuator.
      i have changed this a few times
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Just something to check, but I've had jamming caused by the door not shutting all they way and not enough pressure is on the vertical transport roller. I don't remember the jam code. All the rollers and clutch had been replaced but it continued to jam. When I pushed on the lower front part of the door it wouldn't jam. If you can push in the door and there's more than 1/4 in of play that may be your problem. What I did was removed the cover (see image) that had the latch and put a shim between the cover and frame so that the latch would angle toward the transfer belt more. The shim has to go opposite the latch to angle it inwards. Another time I cut a small piece of plastic and glued it to the latch.
        • splblazer91
          • Jul 2014
          • 204
          Clean the Registration Assy Bushings. Has fixed all of mine with this issue. Service Manual says Fuser Jam but i have yet to see one jam in the fuser with this code.
          • avecosat
            • Jun 2012
            • 303
            Thanks to all , is only 4K and six months old .
            • avecosat
              • Jun 2012
              • 303
              [ATTACH=CONFIG]29359[/ATTACH]
              • giddyupngo
                • Oct 2014
                • 109
                I am also getting 30-03 jams from all trays, but on a C554e. I replaced Clutch 8, replaced tires in Tray 1 and 2, but problem came back. This is a high meter machine, over 1.5 million copies. I was interested in the door problem as a possible solution, but the vertical transport roller is between Tray 1 and 2 feed units, so 30-03 jams in Tray 1 would rule out the vertical transport roller as the culprit. Paper jams about halfway through the fuser, almost reaching the exit rollers. Right now my possibilities to check are
                Replace fuser (hidden paper jam)
                Tighten door (hold in to check for improvement)
                Check length of actuators (Worn down by 1.5 million pieces of paper?)
                Check door isn't popping open momentarily, check sensors/actuators
                Check Registration roller bearings, see if it turns tightly.
                Any other suggestions would be appreciated.
                • kanic
                  • Nov 2009
                  • 6
                  Faulty PS3, exit sensor. Replace sensor and actuator. If you have that many copies also replace the duplex sensor located adjacent to PS3.
                  • kanic
                    • Nov 2009
                    • 6
                    With over a million copies your PS3 sensor is probably bad, replace it along with the actuator. There's a duplex sensor you should change when you have that assembly out.
                    • giddyupngo
                      • Oct 2014
                      • 109
                      Just an update, the problem turned out to be the new clutch I installed (clutch #8). After speaking with Konica Minolta technical support, they recommended removing the clutch and cleaning it, as they have had some issues with some new clutches having excess grease inside.
                      I removed the clutch, took it apart, and cleaned the plates with
                      "Blue Shower Maintenance Cleaner". After reassembling, I ran over 1,000 sheets through using paper passage test with alternating trays (no jams). The plates of the clutch were basically clean, the towel I cleaned it with showed a little dirt/grease. Could possibly have been a loose connection, by dissembling and reassembling I also re-seated a large number of connections. The bulletin also mentions making sure the wires leading to clutch #8 are not too tight, which probably could lead to loosening of the connection through vibration. Re-route it if necessary. This clutch is really buried, expect this fix to take 2-4 hours.
                      The bulletin number is KBA01201071
                      Here is the link to the bulletin, you must be logged in to Konica Minolta first.
                      Display
                      • jonbonse
                        • Jun 2009
                        • 730
                        Hi all
                        sorry to bring up an old thread but i just wanted to as the question:
                        I have this jam code but it only occurs when printing from cassette 3! This makes me assume the reg roller bushings, clutch 8, ps3 ps1 are all ok?
                        I have fitted the washers to the lower right door for jam code 2002 however it does not have the new modded transport roller. It does have new cassette rollers to include the new ribbed pickup roller...
                        • Albonline
                          • Sep 2008
                          • 1131
                          Originally posted by jonbonse
                          Hi all
                          what about the one way rollers
                          • jonbonse
                            • Jun 2009
                            • 730
                            Which ones are these to be sure?
                            • tsbservice
                              Field tech
                              • 7904
                              Those in cassette 3 paper feed unit. Just swap them with another from working tray and test if don't have spare ones.
